questions on foam under floor?
starcraftstriper
I have a starcraft king fisher 16foot. It has the foam under the deck and its holding water. So i want to take it out but im sure it wouldnt be safe to put nothing back in so what can i put in it?
CheapboatKev
Re: questions on foam under floor?
Glad you ask! This has never been debated ever! lol..Ok maybe once or twice.
You have a LOT of options to go with beginning with no foam actually..
But I would say the following list in order are what is currently in use.
1. Closed cell pink foam from any big box DIY center
2. Poured in self expanding foam (a nightmare to remove and probably whats under your deck now.
3. POOL NOODLES (yes, 99 cent pool noodles)
barato
pool noodles or similar closed cell foam (sometimes used to pack computers & related products).
i've used up my supply of noodles and can't find a good source...one will sell me a case for $41, but with $46 shipping! anyone have suggestions for finding em this time of year?
calboats
I bought 1 inch sheet insulating foam, Home Depot, the white closed bead stuff doesn't hold water like open cell foam does. Use a "keyhole" thin pointy saw to shape the foam to stack in fairly snug. Keep it in place with spray plastic foam like they use behind electrical outlets, it swells up and locks the sheets in place. Once that sets up, you can reinstall the floor boards.
I make "access ports" on the floor board centerline so I can access the keel area, with wood bulkheads to contain foam, and I get extra paddle, rods, or ?? storage too.
I'm not in love with the liquid two part mix and "watch it grow" foam mixes. I like to be able to remove the sheets if I damage the bottom somehow, or check for water if the floorboard comes unstuck.
Just a thought, if you are redoing the floor boards -- get the (poison kills mould) cheapest anti freeze, mop it on the wood, both sides, after fitting and before epoxying in place -- let it set 4-5 days till fully dry -- then epoxy in place, no more floorboard rot, and f'glass bonds to the ply just as well, maybe better.
No rot, that's hot !! Good Luck, Cal
starcraftstriper
How many pool noodles would i need? is there an equation or something? And would they hold water? because last time i was on the lake fishing in the rain all the foam held water and will be there forever til i replace im sure
ezmobee
I fit 72 noodles in my 18' SS.
http://i176.photobucket.com/albums/w200/ezmobee/New Boat/DSCF2378.jpg
http://i176.photobucket.com/albums/w200/ezmobee/New Boat/DSCF2383.jpg
I bought mine here in the winter for this not good at all price
http://www.flaghouse.com/Water-Noodle-Set-Set-of-24-item-8052
Similare here
http://www.poolcenter.com/pooltoys_noodles_water_logs.htm
even worse price here
http://pooltoy.com/orwanoca24.html
Or I have heard you can order them on Dollar Tree's site and have them shipped to the store
http://www.dollartree.com/new-arriv...am-water-noodles/215c334c334p308025/index.pro (best price by far)
barato
72? you've given me a goal to shooot for.
thanks for the sourcing info!
starcraftstriper
So let me get this right you just lay the noodles in right? You dont secure them down or anything
ezmobee
Correct. They don't exactly rattle. I stuffed 'em pretty tight though.
Stratosman86
I used both noodles and 2" sheet in mine. There are noodles under the sheet as well. I split the noodles in half between the ribs to allow me to get more in on the sides. I used 62 noodles total and have one full case lef if anyone is interested. One hard lesson I did learn though was to make sure that in the area where you are going to bolt your seat pedestals, if you use the new Toggler bolts, leave enough room for the toggles to open.
Have fun,
Darren
starcraftstriper
Have fun,
Darren
Thanks for the pictures it helps me visualize
ezmobee
Funny, I was wondering how you were having a hard time shoving a toggle into a noodle pile I'd forgotten you'd used sheet foam in the middle. Dulp!
