I'm sooooo embarrassed!!! Forgot how to field strip SKS!!
ezbtr
It's been a few years, aw geez, told my step dad, and he was gonna email me, just trying to get trigger assembly out to deep clean, I'll look it up on the web, LOL.
I know I can use a bullet to disengage assembly, just missing a few pointers :)
srt4bad
Re: I'm sooooo embarrassed!!! Forgot how to field strip SKS!!
ak47.net
WizeOne
Bang! Yer dead!:eek::D
mudslinging79
**** the rifle, engage safety, press in the dimple with a bullettip and it pops out. make sure the safety is on for removal and instalation.
ezbtr
done it all, damn trigger housing wont come out - it did come back to me after seeing video - all else is out??????? Scratching head.....
mudslinging79
**** rifle? safetu engaged?
ezbtr
yup...
mike243
trade it for a good bolt action :) ,mike243
ezbtr
just got it, holy cow!! Used a punch to press down, HARD on dimple and it popped out, it was never this tough!! Soaking in hot soapy water, brushed clean, will clean rest, lube and reassemble. Then see if my occasional double tap goes away.
Thanks guys!
mudslinging79
pull out the bolt carrier and strip it down, specially the firing pin. thats most likely your source of double tap. the pin should rattle when you shake the carrier. also look at the bolt face and make sure its flat around the hole for the firing pin. most people use a large drill bit and recess the hole slightly, twisting the bit by hand. its called the volcano effect.
i had a similar problem with double tap, i did the drill bit thing, as well as hit the firing pin with 600 grit paper to smooth things up
this link has helped me out severial times...
http://www.sksboards.com/smf/index.php
mudslinging79
last thing one needs is to have the wrong person notice the slamfire, feds knocking at your door has a habit of ruining ones day
