1994 DT 40 has 2 issues one under load trim bleeds down. No leaks but bleeds down. Also at full throttle light on bottom right of oil/temp etc gauge comes on. Not sure what alarm even is.
Re: 1994 DT40 Trim bleeds down also alarm @ full throttle
That is strange that it bleeds down with no leaks, maybe you should go one pin up so it doesn't go down too far ...... make sure your oil reservoir is always 75% full ....
One pin UP? It has to be bleeding by the bypass or the piston but not sure how to prove it. The alarm thing bothers me more. Not sure what the alarm is. Where can I buy service mamuals for this motor?
