Whats an anti cavitation plate?
tx1961whaler
Re: Whats an anti cavitaion plate?
Yes. It is the horizontal surface just above the prop. Also called an antiventilation plate
75-JOHNSON
Thank you very much. does this have to be level with the bottom of the boat when the motor is 90 degress to the boat?
nate1220
it depends on how you have your motor trimmed.
Bob_VT
It is best that the motor is mounted on the boat so that plate is even or about an inch above the keel.
75-JOHNSON
If it is trimmed ALL the way down.. trying to figure out if i need to move the engine up or down.
75-JOHNSON
And the keel is the lower-most part of the boat at the back? (my boat is a fibreglass trihull)
nate1220
bob your from castleton, I live in North clarendon
nate1220
when the motor is trimmed all the way down the cav. plate should be flush or up to 1 to 1.5 inches above the keel (the lowet partof the hull or the rib running down the center)
NSBCraig
Re: Whats an anti cavitation plate?
Not trimmed all the way down but parallel.
The plate above the prop on an I/O or Outboard is an antiventilation plate. Calling it an anticavitation plate is incorrect.
Cavitation is different than ventilation. Ventilation is when air gets to the prop. The AV plate stops that ventilation.
Cavitation is caused by low pressure or vacuum behind the trailing edge of the prop. Ofter, it erodes the metal of the prop, due to the boiling of the water and other forces..
75-JOHNSON
ok so i moved the motor up a bit to get the "plate" at a better level. Now exactly what will this do for me? will the effects be very noticable or not?
Note: previously the antiventilation plate was about 1.5 inches below the keel of the boat when trimmed down. now it is about 1 inch above the keel.
JB
You will now have less drag, which should be noticable at planing speed.
Once you have the boat on plane, trim it out until rpm peaks but short of prop ventilation or boat porpoising.
