frankm1188
Thread starter- Joined
- Jul 22, 2010
- 5
ok i have a 2001 four winns bow rider. it has a 4.3l engine in it. the other day on the water it was starting to run really high in temp so i cut it off and brought it in. i changed the impeller which was all beat up, flushed the hoses all out and put everything back togather. when i put the muffs on and started there was no water being sucked into the engine...i tried to put pressure on the muffs to get the water started but no luck. i took the hoses off the pump and ran water through the intake and exhaust with both working fine. i also wait a minute to get the temp up thinking maybe the thermostat was still closed but nothing. what could it be not letting the water get sucked up?
