mstahl1171
- Mar 16, 2010
- 209
I have a 1962 Lark V. Today while running around the bay my forward gear went out. I was able to shift to reverse and nuetral just fine but no forward gear. I check the voltage to the forward coil and it is at 12.2 volts When I got home I found water in the lower unit so I can assume maybe the water shorted the coil out? I do have a spare set of coils that are NOS. My big question is this....any idea of what I should pay to have the lower unit sealed and new coils installed? When I pulled the boat out of the water I found oil leaking around the prop shaft...So I guess the bearing and seal is bad.
Any advise or help is greatly appreciated
Mark
Mark
