going forward in reverse and reverse in forward
theologyman
The boat goes forward in reverse and reverse when put in forward. When put in forward the cable at the motor goes forward and when in reverse the cable goes back just like it is supposed to. What else could cause this problem? The motor is a 1977 85 Mercury outboard.
Re: going forward in reverse and reverse in forward
Just take the throttle off and turn it around!
haha just kidding, i have never heard of this happening before...Good Luck!
I will bet someone had the gearcase off to repair the waterpump. It needs to be removed again and the shift shaft turned CCW until it clicks into neutral. Now set the MerControl to neutral and reassemble.
westexasrepublic
X2 thats what happend
