I am looking at buying a 1994 SeaPro 180cc with a 1994 Johnson 112 SPL on it. The problem with it is that the motors runs in idle but as soon as you put it in gear it konks out.
The guy who I am buying it from is claiming that the 2 pistons on the port side of the engine are blown due to "bad gas". He said that he thought it could have been the head gasket so he replaced that but it didnt change anything so he is sticking with the blown pistons.
I had a boat mechanic buddy (mainly inboard motors though) of mine take a look at it with me and we did compression tests and the cylinders on the port side are both at 80 psi while the starboard cylinders are in the 100 psi range.
I am trying to figure out what the possible problems could be and if it would be worth getting the boat (great deal) and either trying to fix the motor myself or just go out an find another motor OR if I should just stay away.
Any insight would be much appreciated.
