no top end 50hp
gilbert1244
I have a 1995 50hp johnson everything works great until i get to half speed when i open it up i can't get any more speed & the buzzer goes off every now & then does anybody have any ideas whats wrong THANKS
Lion hunter
Re: no top end 50hp
I don't know how many different buzzer alarms are on the newer motors but it seems that overheat and low oil are the two main ones and where I'd start.
HybridMX6
Re: no top end 50hp
If it's not revving past half power, and giving an alarm, I'd suggest the carbs are fouled, and causing it to run lean in 1 cylinder, leading to low power, and an overheat situation on that 1 cylinder due to lack of lubrication, causing the alarm.
jimdd810
Re: no top end 50hp
I agree its time for a carb overhaul. I would pull the plugs to check and see if they are burning about the same. I would do a compression test also.
jtexas
Re: no top end 50hp
when the alarm sounds a steady tone, it means the motor is overheating and needs to be shut down like right now!
a continual beep-beep-beep indicates fuel restriction or oil pump malfunction, and a single beep every half minute or so means low oil reservoir level.
I agree, carb rebuild is most likely, but I would do the compression test first, it will tell if you've taken any damage by running it hot. I would also think seriously about changing the water pump impeller, just to be safe.
gilbert1244
Re: no top end 50hp
does anybody know the idle & air ajustments for 1995 50hp johnson before i start messing around with the carbs
