ramelton35
Thread starter- Joined
- Jul 11, 2010
- 15
I just purchased my first boat and it is a 2004 SR 180 BR with a Mercruiser 3.0L. I have had the boat out several times now and the problems seem to get worse.
First off it is getting more and more difficult to start. The last time I was out it took a long time to get it to turn over and when it did it just died. After a little while I got it to turn over and run. About a 15 min. later I turned the ignition off and it backfired about 5 or 6 times. I turned it off a little while after that and it backfired once. The boat runs good and has no trouble accelerating. Any ideas on the ignition and backfiring?
Also my speedometer stopped working last time I was out. Does a hose or something just need to be blown out? Where is that located?
I was also told by a guy that my bellows on my lower unit were stretched out and should be replaced. He said that if they weren't replaced they could be quite expensive to fix. Not knowing much about boating I had no idea what he is talking about. Is there an advantage to fixing these before they go bad? What happens if they do go bad? He also said that something needs to be trimmed and doesn't look like it can be trimmed anymore. Is he talking about the lower unit trim?
Please help a new boater out, Thanks!
