OMC Cobra Trim stop/interupt???
LAC_STS
Master Chief Petty Officer
I have an OMC Cobra outdrive and have been reading on here about problems with the gauge and trim.
I can understand not needing the gauge. My gauge doesn't work. When the IGN is off is is all the way down (the gauge), when I turn the key on the gauge goes to all the way up no matter where the out drive is.
Problem is (I think) as I have been reading isn't the trim pump supposed to stop when it gets to the top or bottom?
When I trim mine when the drive gets all the way up or all the way down the trim pump just makes a clicking sound like stripped gears or something.
I know its bad to do this but I just got the boat and was still trying to get adjusted to how long it takes to go up or down.
So my question is, is there supposed to be something that cuts the trim pump off when I get to all the way up or all the way down?
Does if have to do with the gauge? Meaning do I have to have the gauge working to get the trim interrupt to work?
If so, Where is all this stuff and how do I trouble shoot it?
Thanks
a70eliminator
Re: OMC Cobra Trim stop/interupt???
My OMC Cobra trim pump doesn't stop either, It squeels when it's at the end of it's travel and I release the button, the system has a relief valve that opens to bypass so you can't damage anything, but you still want to let off immediatly following the squeel, I tent to bump it back just a tad after the squeel.
The trim senders are no longer available. There is no autostop that I'm aware of.
LAC_STS
Does your gauge work?
a70eliminator
Yes my gauge works. It reads full up just before the prop blows out, depending on the load.
Lou C
BTW Sierra now makes a Cobra trim sender, I got one for my 88 Cobra here on Iboats....
