The320
Thread starter- Joined
- Jun 30, 2008
- 27
I have a 1971 Evinrude 50 hp outboard. It is a two Stroke. Model #50172S. Long Shaft. Its on a 25 foot harris pontoon. It keeps stalling out when I put it in gear. I originally had a problem with one of the cyliders not firing (top). Causing the bottom one to foul out. I have so far changed the Upper crank seal which made it run better, strong spark with tester both cylinders and 120 pressure in both. But now its stalling as soon as I put it in gear. Carbs Are Spotless, Floats work great. Went down to the Reed plates and those are clean only because I noticed that there was a lot of gas dumping into the front carb canister, looked like from both carbs. I have to replace the intake gasket, couldn't get reed plates out without destroying it, and the gasket was pretty dried out and shot. But due to the reed plates looking good, I kinda feel as though I'm up against a wall here. Any suggestions please. Trying to avoid pulling power head or splitting it. And can't really get timing down/carbs adjusted right until I solve this fuel dumping problem. I am praying it is not a vaccum leak.
Sincerely,
The 320
Sincerely,
The 320
