Tim Frank
- Jul 29, 2008
- 5,351
Replacing the impeller on this motor and decided to really make my life difficult by dealing with a minor leak in the gearcase.
Have everything disassembled and judging by the condition of all the hard parts probably did not need to do this at all.
Too late now....
Three questions:
1) The OEM manual says that you should use OMC Gasket Sealing compound #317201 on the bores of all seals....on various screw threads when you reinstall them...and "OMC Adhesive M" on the impeller plate....and the gearcase "ribbon" seal.
Does the success of this rebuild depend on using the spec'd sealant or can i use Permatec for all? (I already asked about the "ribbon seal" in another thread and opinion was PermaTec was fine there. I would think that Permatec would "lock" the threads sufficiently but still be service-removable....or would removable Loctite be better)
2) There are a bunch of "special service Tools" spec'd for a few operations.
Mainly bushing R&R and seal R&R.
Again, are these absolutely necessary, or using sound judgment can I make up something that will do the job?
3) There is a small circlip called the "driveshaft retaining ring". On principal I would just replace it, but it is "no longer available".
Any reason that I couldn't take it to a good industrial supply shop and buy a circlip to fit? I can't think why not, but second opinions are always good.
Too late now....
Three questions:
