eightpointup
Thread starter- Joined
- Apr 23, 2008
- 32
1982 mercury 50 hp 4 cylinder
History is I bought it and was told the first time to start it each year he used starting fluid. I tried it (I now know its a bad idea). It started but I couldn't get it to idle. I could give it about 3/4 throttle in neutral and it would run but would die it when I tried cutting the throttle back. I tried it again the next day and started a small fire due to the starting fluid. I melted the choke linkage the plastic on one choke shaft. I removed the carbs ordered the parts after a ton of searching. I did not order kits to rebuild yet due to money.
Actual Question Before installing the carbs is there anything I can due to them as far as adjustments or cleaning without rebuild kits to have a better chance at the operating correctly?
Thank you
Thank you
