4.3 with no compression on 2 cyl....why?
pmtom1
Hey guys, Ive just started a new project on a 1989 Wellcraft. Looking at replacement engine for a seized 3.7. I have a 4.3 (I understand the mounting and gear issues) available cheap that has no comp on two cylinders. What are the most common causes and repairs of this? Piston, rings and maybe some cylinder wall damage?
PS...any one that has successfully gone from 3.7 to 4.3, Id love to ask a couple questions via email!
Thanks.... tom
Haut Medoc
Re: 4.3 with no compression on 2 cyl....why?
0 compression is usually a valve issue.....
Or a hole in the top of the piston caused by detonation.....
You will still get some compression with scored walls, cracked rings...;)
If the cylinders are adjacent it could be a head gasket.
A leak down test on those two cylinders will get you much closer to the answer.
Bifflefan
Thanks.... tom
What 2 cylinders?
If they are side by each then its probably a blown head gasket. If not, like stated above, a valve or a hole the piston.
pmtom1
Thanks Guys.... Will check and report back!
