Quick compression question
mamm7215
Hi, I tested the compression on my motor but I did it one cylinder at a time with the other spark plugs still in. I've read that you should remove all plugs, THEN do the test. Little confused. Is there that much difference? I got a 120-120-119-120 reading when I did it.
Thanks.
'91 Johnson 90hp V4 Crossfire.
wilde1j
Re: Quick compression question
Your compression's fine. Most people here remove all plugs, then check each hole w/ plugs out, though.
Boss Hawg
True-
I do mine one plug out at a time-(just my way)
Readings should be the same (i think) either way :)
+1 on the good readings :cool:
mamm7215
Thanks! Yeah I was pretty happy with them but then worried if my procedure was incorrect-would the results be skewed...but good enough, now.
Thanks again!
