Re: Johnson 60 HP model J60ELESM
Hi K,
I'm not familiar with your motor in particular but here are a few possibilities.
It could be a vent issue. Does it happen with the tank cap loose ?
Is the bulb "soft" when you pump it ? If it is a suction feed system, air leaks at the connections will result in air in the fuel lines. Most connectors have an "O" Ring that can deteriorate and cause these symptoms.
B53
