Mercruiser 4bbl Carb Question...
ryflyy
Do I need to remove the entire carb from the motor...or can I just pull off the upper part of the carb?
haulnazz15
Re: Mercruiser 4bbl Carb Question...
It would probably help if we knew what you were trying to do. The carb either is on or off the engine, it would be a terrible mistake to diassemble a carb which still mounted to the engine.
ryflyy
the motor dogs out when i WOT, I wanted to check the carb and see if there was any build of any kind--and clean it.
Ayuh,... Then take if Off, 'n Rebuild it....
