hdman97
- May 11, 2010
- 65
How do these typically go bad?
I have done some searches here and it seems most problems are no spark at all.
I have an older 45hp clasic 50 (1989) this motor has few hours on it.
It wasn't used for several years.I replaced the impeller,mixed fresh gas in a new fuel tank put on the muffs and fired it up ran it for several mins fine.
Took it to the lake started right up ran wot for about 3 mins and then it started to bog down sometimes returning to wot.
Got it home checked for spark found ok all 4 cyls.
My question.... is my problem with the switch box? How can I test this?
Sounds like it is not running on all cyls, problem comes and goes.
Thanks .............
Rick
Rick
