stumped
mraney
when i pull #1 plug wire there is no change in sound like others. have good compression at 175 psi. swaped plugs,coils but problem stay's at #1 hole.It is a 1998 120 h.p. seems to run ok in water,any advice?
jerryjerry05
Re: stumped
Did you actually check the spark?Put on a sparkie and see if it's there.$6 at most auto stores.If you have spark and it doesn't affect the motor when you remove the lead,then do another compression test.
I had a motor with 150# on all three but the head gasket was still bad.J
Oh yea check the reeds too,LJ
bashr52
Re: stumped
If the spark and compression check out good, verify there is actually gas getting to that cylinder.
mraney
Re: stumped
pulled the top carb. sure enough broken reed left bank any suggestions on good place to find the parts have looked a few places but no luck. Thanks for the help.
