svillebrian
- Jun 29, 2008
- 41
I have a 2001 90hp 60 degree Johnson. I was having some problems with the motor running rough at idle and staying running at times during idle. Other than that, the motor was operating fine. Noticed that the fuel bowls were leaking and thought this was the problem. Did a quick fix and sealed the outside of the bowls and got the leaks stopped. I pulled the carbs off and put them back on with new o-rings. Took it out and it started fine. it didnt want to get on a plane quick and was sluggish till about 3500 rpms, then it accelerated quick till about 4500rpm and dropped off again. Couldnt get over 4600 rpms, but was running smooth. pulled the carbs off again and just reuilt them. Put it back together and it started and idled just fine. Reved it up in idle in the driveway and did fine again till about 4000 rpms and then it bogged down and shut off. Starts and idles fine, but just keeps bogging down at high rpms. Any suggestions on what to try next?? Need to get it running quick!
