Re: fule dumping the water
Are you sure it gas??? my father in law thought mine was flooded the first time we took mine out. he thought the rainbow effect on water was fuel, but the trim cyclinder had oil on them from where i had drained and worked on them. so are you sure it fuel and not oil leaking out of something? it may be carbs are stuck and leaking out extra fuel as you lower motor into water. mine does leak a little what ever fuel is in carbs as i turn motor off after trailering, does have a drop of fuel come out as i tilt it up. so it may be just extra not burning off! or you may have a line with a hole. look around tell us more info about what you find and let us help.
