FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
1996 Merc 5HP 2 stroke - used first couple times this season worked fine; new gas/oil mixture and oil lower unit; stalled last time out, changed plug and gas (again) just to be sure... idled but would not throttle up. Took in for service and was told diaphram in fuel pump was unseated so they replaced, I was advised to install new, so installed all new with rebuild carb kit, but now, it wont even crank... has spark and getting fuel to pump. I tried to adjust mixture a couple turns and may now be off the mark - is there a way to test or adjust to start? Any other suggestions?? I'm stumped.
First of all, are you getting fuel in the bowl.
If you are, make sure the fuel level in the bowl is set correctly then set the mixture screw to 2 turns out. This should get you started.
I spent some time training IBM computer field engineers. The hardest thing for them to learn was this.
If you walk up to a running machine, do something to it, and it now does not run, it's what you did.
