runnin rooster
Thread starter- Joined
- Jun 14, 2010
- 6
I am new to this board and am hoping to get some diagnosis/repair help with my outboard motor. My goal is to get it running well again without sinking a lot of $ into it, because simply put, the $ aren?t there and the boat is not worth it. I have had an 88 Bass Tracker with a 45hp ?Mercury Classic 50? on it for several years. We are not convenient to good fishing/boating waters so any excursion is an all day event. Unfortunately with two young kids and two jobs, it does not get out much, usually 3-4 times a year. The rest of the time it sits in the open under a well fitting, properly pitched cover.
I will try to provide all relevant information so excuse me if I get long winded. When I bought it about 10-12 years ago, at the advice of the owner of a local marina, I disconnected the oil injector and mix directly in the tank. I always mixed in some Seafoam in the last tank of the year. It ran well until late 08 when it started intermittently running at only about half RPM, but would suddenly kick in and run fine the rest of the day. It became progressively worse. In early 09 I changed the plugs and wires with no improvement. Shortly thereafter I put in the marina and they replaced the power distribution box, new battery and a couple other things to the tune of $700. The boat is likely not worth much more. It ran great the few subsequent times I got it out last year, and a couple weekends ago, my first fishing outing of 2010. That trip was entirely on last season?s gas and the motor ran great.
But Sunday I took the kids tubing. I filled the tank and mixed in some Shell 2 cycle outboard oil at 50:1. Again it started out running great but about an hour into tubing I noticed an occasional momentary reduction in RPM at high speed. I would term it a ?soft? miss, smoothly dropping a couple hundred RPM for a few seconds then smoothly coming back, not a sudden cutting in and out. It still idled well and pulled strong off idle. I pulled the cover and could see nothing obviously wrong. As I said, boating is an all day commitment and the kids were having a blast, so we kept it up, admittedly not the right thing to do. Gradually this ?soft? miss came more rapidly and at lower RPMs. By the end of the day it was not idling well. It would idle smoothly, then drop off idle to almost stalling but never did, then come back to idle RPM. I would still characterize it as a ?soft? miss but it was so pervasive the motor would not pull strongly off idle. It still planed out but the motor was obviously lacking something and running about half speed, even more noticeably under load.
Any suggestions on where to start troubleshooting? I would like to avoid putting it back in the marina if possible. I can not afford to sink several hundred dollars into it each season, especially as little as I use it. I am mechanically inclined enough to be dangerous to a car or motorcycle, my experience ranging from basic maintenance up to replacing a few heads, clutches, and brakes. But I know little to nothing about outboards.
