Omc 4.3 engine alignment after sei rebuild.
LassePelle
Hi :) I have rebuildt my omc transom using the sei conversion kit. Everything worked out wery smooth and i used approx 4 hours on the job.
Here comes the problem. I thought i had aligned the engine good enough, but when i was out on the sea there was a grinding sound coming from the transom and it smellt a little burnt rubber. The sound was not loud and i did not run fast, but i guess this will have to be fixed.
My question is this: Has anyone rebuildt their system using the sei kit and a merc leg? Do u know if the engine needs to be lowered or raised for the alignement to be correct?
I am hoping that i do not need to lift the boat out of the water to do this :) Shouldnt it be possible to hear when the noise dissappears?
Re: Omc 4.3 engine alignment after sei rebuild.
Ayuh,... Are you saying you did all this work,+ Didn't Align it,..??
Did you replace the gimbel bearing,..??
My guess is, Yes, the boat needs to be pulled to complete the job started...
bruceb58
Describe your alignment procedure.
180shabah
I do believe that you are the first on these boards to do that conversion.
You need to contact SEI about your issues.
LassePelle
Hi. I used the drive shaft from the cobra drive to check the alignment. It slided in nice, but when i think about it it may have been that i did not get it in long enough :(
I know i should use the right tools, but everything seemed to be ok. But if the shaft slides in nice thru the gimbal an partiallyinto the coupler i guess it is the front of the engine that needs to be adjusted?
Btw the gimbal bearing is ok. I put my hand in and turned it without any problems.
bruceb58
You need to do it with an alignment bar! Lessons learned I am afraid.
LassePelle
Guess you are right hehe. Well.. i am off to buy tools and try to get someone to lift my boat out of the water :)
180shabah
I wouldn't trust that coupler at this point.
