goosemanhnt4fud
Thread starter- Joined
- Jul 13, 2009
- 20
I have an 83 Mercury 70hp outboard on the boat...
Here is my problem and things I have done so far:
The problem is that it will idle all day long but when I give it full throttle, it will plane out and run for 4 or 5 seconds on plane then sputter and die then as soon as the boat settles I can fire it up right away and it'll run again, When it is up on plane it seems fine and sounds really good, then it seems like the fuel is being shut off???
I have replaced the diaphram in the fuel pump, the filter in between the fuel tank and the motor, the bulb in the fuel line used for priming and the spark plugs and have done a compression test and all three cylinders were at 119...
I am looking for another direction to go...carbs need to be cleaned, maybe the floats?
If anyone can help me out and has any suggestions they will greatly be appreciated. Thanks so much and God Bless!!
