gnarleygnu
Thread starter- Joined
- Apr 1, 2010
- 9
As stated in title, I have a '78 6hp. I've searched the forums extensively, I have the manual but am still super stuck!
Problem: runs rough and lacks power, dies if throttled down to idle, choke taken off or transmission engaged.
This is the specific starting procedure I have to use to get it running which works every time:
1) Idle adjust at lean (all the way counterclockwise)
2) Choke 100% out. 2nd pull motor stutters.
3) Choke 50% out. 2nd pull motor fires up.
As I'm going through the starting ritual I can see a bit of fuel collect and drip out of the carb intake. Don't know if this is normal.
Seems like a fuel problem to me. I changed the old-ish fuel out today and swapped it for fresh non-ethanol fuel.
Fuel filter clean
plugs replaced, gapped.
Carb rebuilt to try to solve issue, no change. One caveat: it was my first carb rebuild, while I blew out all the jets with compressed air and I made sure all the parts were as clean as possible I didn't soak the parts in solvent which I now know I should have. Carb parts looked super clean when I pulled everything apart, other than the float which was really torn up and the float valve which was a bit worn both of which I replaced.
fuel line bulb is firm throughout operation
I feel at a loss here, I don't have the diagnostic skills that I'd like (yet) and thought some of you experts could give me a hand tracking down this problem.
Thanks in advance!
Fuel filter clean
Thanks in advance!
