Re: Can interlux touchups be done?
Hmm as were posting i am doing just that...This i will tell you. Perfection is without a doubt superior to bright sides in both durabilty and appearance...quite a bit actually..Yes you can pop a dock quite hard with perfection and it just takes a beating.
Now as to refinishing..yes you can touch it up in a conventinal manner...It is as simple as isolating the scratch taping it off sanding down the edges and then rebuffing her back to a sheen....However you will notice the spot it will not buff to the orignal sheen...Not gonna happen.
Ive taken the whole boat down again that is i lightly scuffed the surface with 320 grit on all the good paint..the sheen is gone and where there were nicks well it was down to the gel coat...It was as simple as slapping on some new paint letting it dry lightly scuffing the new and then repaint here again.
Be advised as in any paint job it is prep that takes the time...Countless hours..
of sanding...As to the acutal painting time...15minutes and poof your done...
