shane hawkins
- Apr 7, 2010
- 27
Hello got a few issues im looking for insight on for the weekend. I have a 92 3.0 mercruiser alpha 1 gen 2 with est ign. First the boat wants to cut out when giving full throttle and then accelerates great. I have to keep boat idle around 1100 rpm. If i turn down idle screw to 800rpm when warm it will not restart when cold, i have to turn it back up to start. Choke, butterfly seems to be working correctly. I set the choke to one notch to the right of center notch, and mixture screw is turn out 1 1/4 turns timing is set to 1deg btdc. . Im not sure how to set anything else on carb. Any info would be great....
