Tilt/Trim clicking
lakebound&down
Recently i replaced the Tilt/trim solenoid and it still does not raise or lower..all it does is click when the up or down buttons are pushed an ideas..i could use a wiring diagram of the tilt/trim if one is available..it is a 1976 mercrusier 165hp 6cyl...the boat is a mark twain if that matters..thanks
Re: Tilt/Trim clicking
Ayuh,... Merc manual #1, I believe, up in the Adults Only section at the top of this forum...
Don S
#2 is the manual you want. #1 only makes it thru 73,
RRitt
check to make sure solenoid is putting out voltage to trim motor. If it is then either motor is broken or you have lost ground connection.
gryhnd
If that's the electric motor driven trim like my '75 165hp, you might find (future) help in my thread on the entire process I am going through to fix mine:
http://forums.iboats.com/showthread.php?t=399093
Edit: I see someone else replied about it being a Merc, so perhaps my thread isn't relevant.
