i removed my 1991 xr6 150 hp motor to repair a crack across the back, due to the previous owner not using the motor stand. after putting it back on i was suprised when the motor started right up and seemed to run just fine. first time on the lake after the repairs it runs fine at idle. when not in gear i can hold at 3000 rpm's and temp is 180-200 deg f. when in gear and only 2000 rpm's temp alarm will sound at 243 deg f. stats seem to be good, poppet is operational (i think). tailtale has stream but i think it may be weak. gonna replace the water pump anyway. the think that worries me most is the amount of bubbles that seem to come from the prop area. starts and runs at idle like a champ. bad piston rings? cracked head?
