Ok here I go. I have a 1986 Mercury 4 HP Outboard (Serial # 0A708744) that was woking fine on the lake and was pull started like 6 times no problem then the 7th time it didn't want to start at all. Got home and filled up the bucket to try it a bunch more times and still nothing. I can get it to make a couple hiccups but won't fire more than that. The hiccups sound a little rough to. I did check and it is getting spark. I put in a new plug just to see if that would help but it didn't make any difference. Gas seems to be going in but not sure if it is going as far as it needs to. Where should I go from here?
