FORUM RULES UPDATED - - -
The larger motors don't normally have an adjustment screw or needle, the jetting is fixed.
What makes you think its running rich?
Yes, the jet needs to be changed.
What makes you think it needs to be re-jetted though? Sometimes the jetting isn't perfect, but its normally good enough to not create issues, are you at high altitude.
What plugs are you using, are the floats adjusted correctly, is the thermostat working correctly, how do you typically run the motor, have you de-carbed it recently?
we are both typing too fast and posting before the other person resonds, lol.
I would say it could be a couple of things other than jetting unless you are at high altutude.
2,000 ft could start to effect it, but make sure eveything else is correct before changing the jets. I don't have the link, but they do have recommended jetting for high locations.
