Gear oil leak Alpha 1 Gen 2
Sprint 18.5
I found clean gear oil below engine, between gimble seal and bearing and in the U-joint bellow. I can't find the leak
Sprint 18.5
Re: Gear oil leak Alpha 1 Gen 2
I'll replace the bearing but I can't find the oil leak.
There is fresh clean oil in the bottom of the boat below the engine and in between the seal / gimble bearing also in the U-joint bellow.
Bt Doctur
upper carrier seal in the drive, the one behind the U joints.
Sprint 18.5
The oil in the drive was Milky, this oil is fresh and clean.
Mike
