I thought I had a prop seal problem but....
1973delta
I had convinced my self that I had a bad prop seal, but after thinking ab out it I never really had a problem with it until I replaced the lower unit water pump. Could there be something I could have overlooked that would have caused a small amount of oil to pool in the prop carrier area.
cr2k
Re: I thought I had a prop seal problem but....
If your lower pump housing was overheated it may be warped, your vertical drive shaft seal is in the lower housing. Also may have bad gasket there.
boat127
did you maybe forget to put that quad ring back in that goes between the upper and lower unit
1973delta
is this the seal that slides on the shaft after you mount the pump housing? yes i did.
Bt Doctur
No, it`s a small O ring, flat .It goes between the upper and lower unit just to the right of the water pump housing
1973delta
what does it mount on? the water tube? on the pump housing?
Bt Doctur
In the recessed area just to the right of the stud.Lower part of the epic.
Bt Doctur
1973delta
any thing else i might have over looked?
bigskiohio
Master Chief Petty Officer
the quad ring on mine is not in water pump it is on the outer case sandwiched between both halves. But mine might be alot older or different model.
