Hi guys,
My first post here and I just joined happy boating community.
Need your help!!!
Got boat and motor as a gift from friend.
About my motor. Wnt to mechanic shop today. Based on schematics model number is 75552R. No tags, nothing.
Motor runs, shifts gear really hard.
When I opened drain hole in lower unit, mix of water and oil came out.
Removed lower unit. Did pressure test. Bubbles going out of water intake hole (see image). No bubbles going from other places.
So. It seems to me the leak inside the water pump, because no bubbles from outside water pump unit. Am I right?
Kind of hesitate to open/remove water pump unit.. Anything I should be aware?
Here I am...
Where I can find seal kit for 1965 year model? I put more pictures if anyone can recognize the motor model.
Thank You!!
Need your help!!!
Here I am...
Thank You!!
