Need Help Finding a Manual
uncwgrad1
I have a 2003 4.3L and can't find a manual to match in the index. Can someone point me in the right direction?
Don S
Re: Need Help Finding a Manual
Post the SN of your engine. Along with the type of drive, carbed or EFI etc. Mercruiser does not list things by year after 1998.
uncwgrad1
serial #: M378066
It is a carb motor with an Alpha drive.
Don S
With that serial number, you have a 1998 engine, not a 2003.
Here is what I show from the dealer program.
The way this program works, is you put in your serial number and it will give you the model number.
attachment.php
Then you can use the model number to locate the year from the next section.
attachment.php
uncwgrad1
So, would they put a 98 model i na 2003 boat? Or is it just classified as a 98-up? Can you tell the HP rating?
uncwgrad1
So I need #25 manual form the index?
Don S
I doubt a manufacturer would put a 98 motor in a 2003 boat. But I also have no idea what make boat you have.
Most likely the engine was damaged/destroyed and a 98 used engine was found to replace it. Not uncommon, many DIYers on this site find used engines and install them to replace one that went bad.
The manual you want is #25 from the adults only sticky.
uncwgrad1
Thanks Don for all your helpI I have a 2003 Glastron SX-195. If I give you all three serials, can you tell if it as a match? the boat only has 37 hours on it and in immaculate shape...does not sound or look like a like a transplant. I wonder if there is a Glastron look-up using the H.I.N.?
Transom: 0M552890
Drive: 0M450642
Engine: M378066
Don S
Your best bet would be to call Glastron with your HIN number and your engine and drive numbers and see if they match up with what was in the boat from the factory.
Lots of hurricane damaged boats in the south with good engines and drives, along with many good hulls with water damaged engines and drives. Think about the possibilities of swapping things to get a good boat, then sell for a profit.
uncwgrad1
Thanks Don! Can you tell the gear ratio from the stern drive serial? The number in the decal is illegible
Don S
Nope, sorry.
Fun Times
Transom: 0M552890
Drive: 0M450642
Engine: M378066
All the numbers match up to a 2003 SX 195 BR GLASTRON.
Engine serial number: 0M378066 Model number 4211025PS 1998M MERCRUISER 4.3L ALPHA 2 PC 4.3L ALPHA
DRV: 0M450642 5121400LS MERCRUISER ALPHA 1.81:1
TRN: 0M552890 6111001LS MERCRUISER ALPHA TRANSOM
Engine manufacture Date: 09/13/2002
This is an unusual situation to where it makes it hard to find your service manual.:confused:
With your situation in trying to find the correct service manual for your engine with your engine serial number I'm going to recommend that you call Mercruiser directly at 405-743-6566 and ask them to look up what service manual you need for your engine.
http://www.mercurymarine.com/utility/contact/index.php
I know I can take a guess at what manual is correct for your engine, But to be honest it would only be a guess.
The manual number that comes up for your engine serial number number (32) is incorrect because that covers EFI and your engine has a carburetor(correct)???
My belief is, it will be number 25, But you should call for a second opinion.
If you do call, Could you let us know what they tell you? Thanks, And good luck with it.
Don S
That is sad that a manufacture is using 5 year old engine packages in boats.
It's not even a question which manual, it's number 25 for a 98 engine, and number 14 for the drive and transom shield. I just have a problem with the year difference from a boat sold as a new boat in 2003 having a 1998 engine and drive package.
uncwgrad1
Thanks for this...got a little worried I had mutt of a boat going here:D
But if I'm reading this right the engine was manufactured in 2002, not 98...correct?
And yes...it is a carb. engine
Fun Times
You are correct, the engine was made on 09/13/2002 ;)
Carbed engines should be 190 hp.
MPI's was 220ish hp
Don S
If you look at what Boat Tech posted (Below) and look at the part circled in red, you will see that the engine is (or should I say MADE TO) 98 specs, and the part circled in blue shows that the engine made to 98 specs was built in 2002 and put in a 2003 boat, which is very common.
IF, that is what was done, then manual 25 is the one you need. The engine block itself is the same rather 98 or 04 or whatever. It's all about the accessories. Since the accessories are the same as a 98, then then 25 is your manual, and parts list.
attachment.php
uncwgrad1
Thank you both! I hope I can help someone in the future as much as you have helped me this evening!!! :)
