OMC gear oil
BLC
What gear oil should be used in the omc out drives.
Don S
Re: OMC gear oil
OMC gear lube..................
Don S
Re: OMC gear oil
Think it might help if you mention WHICH OMC outdrive you have, model number, year, etc ????????
BLC
Re: OMC gear oil
1989 2.3L cobra
BLC
Re: OMC gear oil
SOOO... nobody knows...... or nobody cares.........
I realize the service manual calls for OMC Hi-Vis gear lubracant, But I can't find any around here. Don't even know if it is still made. Is there another type. Will the merc oil or outboard leg oil work?
Don S
Re: OMC gear oil
Hi Vis is still made, another option is the Mercury Hi Performance gear lube. It's a blue green to green in color. Any Merc dealer, or even Wally world carries it.
MRS
Re: OMC gear oil
BLC, I have a 86 Cobra and do run the Merc Hi performance in it has the yellow lable on it. It is what you should run anyway you can find every where even wally world and Napa the Hi vis cannot find every where. Drain and refill with the merc oil and you will be good to go just make sure you add in the right way....
Re: OMC gear oil
I run 90W Royal Purple in my drive, great stuff, but I do believe that you can run any GL-5 gear oil in the unit.
BLC
Re: OMC gear oil
Thanks guys. I checked with the local merc dealer for the hi preformace gear lube and they have lots.
