Redrig
Master Chief Petty Officer
- Oct 13, 2009
- 871
Hello,
I recently tore into my 1977 OMC electric shift, I have to replace my lower and while I am in there I am going to replace the raw water pump as well.
I took the impeller housing off and marked everything, while I was cleaning off all of the grease unfortunately I wiped off my mark for aligning the housing into the upper.
I am assuming that this has to lined up correctly for the water to flow right and I have no idea how to line up.
in these pics I have numbered the different water passages on the impeller housing as well as the bottom of the upper where it mounts into.
can anyone tell me which passages or numbers that I need to align when I am putting this back in, sadly enough my manual doesnt cover this.
below are the pics of them, thank you in advance for any help
