Diagnostic software
Luis Valdez
Hi everybody. Does someone know if the 0777231 Diagnostic Software PC Version, will be able to work with my Evinrude E-TEC (E115DSLSCR) year 2008?
Thanks in advance.
wilde1j
Re: Diagnostic software
I think the latest version is v 4.4 ... I have 4.2 which I think covers thru and including model yr 2009.
wilde1j
It's copyrighted material. You can purchase it from any BRP Evinrude dealer.
Luis Valdez
I'll do it!!!
Any idea of its price?? and its cable?
Thanks a lot!!!
wilde1j
BRP gets a bunch for the cable. If you're handy with a soldering pencil, I can point you to a source for the pieces to make your own (The Deutsch connector is strictly a mail order item).
Cable construction:
http://continuouswave.com/ubb/Forum6/HTML/002257.html
I would buy a serial cable (straight thru, not null modem) with the right gender DB9 connector for your computer, cut off the end to connect to the Deutsch connector and solder the wires from the cut end to the Deutsch connector.
10 ft cable, other lengths available:
http://www.cablesforless.com/p-928-10-foot-serial-db9-female-to-female.aspx
Cut off one end, and attach a Deutsch connector DT04-3P available for under $12
available here:
http://www.deutschconnector.com/products/deutsch_dt_3-way_connectors.html
No clue on the sw price (I got it when I bought my motors)but I think it's pricey.
RotaryRacer
The cable from BRP is very expensive. There are aftermarket companies that sell them also...but they are still $75-80.
I havn't bought one, but I have seen cables pretty cheap on e-bay. ($25 or so)
CDI Tech Support
Thanks in advance.
If you're interested, our MEDS (Marine Engine Diagnostic System) BRP package covers all Water-Cooled E-TEC 2004-current, Air-Cooled FICHT 1997-1998 & Water-Cooled FICHT 1999-2007:
MEDS Details
MEDS Applications
BRP platform part# is 531-0118B
Retail Price is $2250.00
M
mrcrabs
Guest
I just came from my buddy's place who is a johnson evinrude dealer, latest BRP software is 4.5...he had some serial port issues
wilde1j
The problem is typically, current laptops don't have a real serial port and you need to use a USB to serial converter. All of them don't work or work well.
jhebert
Ensign
There is some anecdotal evidence that the USB-to-Serial converters using the FTDI chip are the most compatible with the Evinrude Diagnostic Software.
I use a Keyspan HS-19A, but I am using an Apple MacBook Pro laptop and run Windows as an emulation. I have not noticed any problems.
I have not tried this particular device myself, but it should be compatible:
http://www.google.com/products/cata...T9qgD4mItwf5taGsBg&ved=0CHcQ8wIwBA#ps-sellers
