Hi everyone, I'm new to the forum and need some big time help on making sure I pick the right engine to perform a poor mans engine swap.
I currently have a 95' Bayliner Capri 2050LS with a Mercruiser 5.0L engine. This engine has a cracked block and I need to replace it for as cheap as possibe and have it last for AT LEAST this season. I'd run it until it dies and then buy a new refurbished engine once it does.
Long story short, I bought the boat used and found out later that the oil was milky white. I'm pretty sure it was due to improper winterization but the seller would say otherwise. Trust me, I almost caught a charge because of this idiot but now I just try to leave it at a lesson learned.
Either way, my plan is to go to a salvage yard or find a running Chevy 305 from a car/truck and then use that engine to replace the one in the boat. Now I know that it will need brass freeze plugs and marine grade gaskets and seals but what I don't know is what years can i play with for the swap. I'd like to find a replacement that was a 95' but my search so far has shown to be pretty difficult. What year engines can I use to replace it? I know its has a 1 bolt rear main seal and a mechanical fuel pump. To convert it to a electronic fuel pump (depending on the replacement I find) isn't hard at all from what I hear but I wanna make sure the right engine is used with minimal parts needed besides what I already have on the boat now in good condition minus the block.
I know a lot of you would tell me not to use a car/truck motor because of the cams and so-on but like a said, it just needs to run for the season and it'll be replaced next year. I've hear both sides of the issue and some people say I'll be fine and could possibly get more than just 1 season out of it and others say that it'll blow up on my before the end of the seaon.
I just need help on knowing what years I can play with and is there anything special I need to worry about for running it in fresh water only.
Sorry so long but I wanted to make sure I included all of my concerns and comments. Details on the current cracked engine are below:
Model: MCM 5.0L
Displacement: 305 CID
Ignition Timing: 8 degrees BTDC
Spark Plugs: AC-MR44T
Engine Rotation: LH
Engine S/N: 0F417977
Transom S/N: 0F468657
Drive S/N: 0F379296
Model: MCM 5.0L
Engine Rotation: LH
Drive S/N: 0F379296
