brianvolt7
- Jun 7, 2008
- 423
Re: Need Help With Force Motor
Here is what happened:
I went ahead and tried to start it with full throttle and an atomizer bottle of fuel. I jumpered strait from the battery to the solenoid, key on.
After several attempts it seemed like it was trying to go when I choked it, but just wont fire.
What is a reed valve and where is it located? If these are the valves in the carb, I just went through them. Or are they behind the carb?
So even though I checked each plug against the block and got an arc, when in the block they may not be firing? Am I understanding this correctly?
