any tips or tricks for grass cutting deck
rbh
Just getting the snowblower off and about to sharpen the blades off the cutting deck from the JD ridem.
Does anyone have tricks or tips for getting it ready for spring???
thanks
Rob
Bob_VT
Re: any tips or tricks for grass cutting deck
I always check to see if they are balanced after I sharpen the blades.
rbh
The old nail in the wall and spin trick?
What angle do you sharpen the blades, 22.5*/ 45*
scipper77
Not much advice on sharpening but...
check the spindles, lube all zerk fittings and steering rack. Check belts also. Remove buildup from bottom of deck. and make sure the deck is level.
rbh
Just going out for the final putty knife scrape down and then power wash.
Bob_VT
I never really worked on what angle ..... just used the body grinder and went for what I remember it used to look like ;)
I do use a thin edge to balance the blade on and whatever side is heavier (low side) gets ground again until the blade sits level.
a70eliminator
I head for the gravel pile at the end of my driveway, aim the discharge shoot to the neighbors yard and let er rip, underside now ready for paint, throw blades away and buy new.
JUST KIDDING JUST KIDDING JUST KIDDING!!!! (#57 gravel works great)
rbh
Well that was fun, went out to do the cutting deck and instead learned how to put a thrown track back on an excavator.
went back, took 30-40 min per blade to sharpen them, a quick weld job plus the scraping (no power wash though), tomorrow install time. :)
Summer Fun
Banned
For $14 a blade I buy new Gator blades every 3 years. :)
They love to chew threw rocks. :eek:
Cofe
I agree with Summer Fun. The gator blades are GREAT. I get the ones made by Oregon on Ebay.
Bart Sr.
You could do as my father-in-law does. After EVERY use he washes AND wipes the entire mower.
Also he sharpens the blades before putting it away for the winter.
His 17 year old Cadet looks and works like new.
xxxflhrci
Washing a deck everytime you use it usually isn't the best idea. It can do more harm than good if you leave any wet grass on the deck.
Anyway, here's my tip: I spray the bottom of my deck with rattlecan bedliner material. The grass doesn't stick as bad and the bedliner doesn't get beaten off by rocks as easily as paint.
