chargerboy
Thread starter- Joined
- Apr 28, 2010
- 362
Just finished putting my Alpha 1 lower unit together and on the boat, now installing the propeller, but when I tighten it to 50lbs torque, it pulls the prop shaft so far forward that the gears don't engage in forward or reverse. Back the prop nut off so the prop is slightly loose, and now forward will work but not reverse. Loosen it so the prop is so loose that it wobbles and i get reverse back. What is the cause of this and how do I fix?
