Ignition Switch Question
CBGale2
Are the ignition switches pretty much all univeral? I have a push to choke switch that the key says Chrysler on it. Want to use it on my 62 Johnson that I added an electric choke on. Just wanted to be sure I didnt fry something.
cougar1985
Re: Ignition Switch Question
says chrysler.is it a boat switch?i use a chris-craft ignition switch for my 63 electshift evinrude starflite and it works fine.
F_R
There are two main types of ignition switches. One is for battery-powered ignition systems, and the second is for magneto-powered systems. "MagCD" falls under the magneto powered catagory.
Using the wrong type may just plain not work, or it may cause serious damage to the igniton system.
CBGale2
Heres a picture of the switch if that helps confirm. Terminals are labeled as M S C B M I.
cougar1985
i originally bought a standard car switch and it tried to start the motor when i hooked it up ,so i went with a marine one and no problems, so you got something there FR!
F_R
CBG, the switch in the picture will work fine with your Gale 40 (Magneto ignition).
CBGale2
The only differance I see is the "1 or I" on it, would that be the acc. terminal that is usually an "A"?
F_R
Yes. On some, the "A" terminal is not active while cranking the motor. No biggie deal with your Gale.
tashasdaddy
diagram
