Oil injection on 1985 150 xr2
mjm478
I just got a 1985 laser 18' bass boat with a 1985 150 blackmax xr2. While inspecting the motor and getting it ready to fire I noticed the oil cap with float on the small oil tank inside the cowl was cracked and seperated at the top. Is there an easy fix for this such as epoxy or where can I find a new one. Also, I haven't ordered a manual for the outboard yet and I was curious to how the vro system works. If I am not mistaken this small tank is filled from the large auxillary tank by a pump driven by the crank and the float under the cap is a sensor for the oil level. I dont think the cracked cap will hurt because it is not an airtight tank due to the overflow line on the tank inside the cowl correct?
mjm478
Re: Oil injection on 1985 150 xr2
Also, should the oil alarm beep at initial start up or can you test it some other way because my biggest fear is oil pump failure.
j_martin
Well, you are mistaken. The engine tank normally runs plumb full tight all the time. It is kept full by a few pounds pressure to the boat tank, that forces the oil to the engine tank. On setup, you crack the cap loose and let it run till it overflows, then tighten it down.
The switch in the cap tells the alarm module if the oil starts to go down in level, indicating that it is not getting oil from the boat tank. At that point, you have about 1/2 hour at WOT of oil left in the tank.
It's cracked because it was overtightened. It has to be replaced if you're going to run the oil injection.
The oil alert power on self test produces a series of beeps. If they are not present, the alarm can't be trusted. Usually it's just a bad beeper or alarm circuit wire. The same circuit and sounder is shared with the overtemp switch. (alarm)
Theory in a nutshell. A check valve on the block (lower forward starboard) supplies pressure to the boat tank. Oil flows to the engine tank. There's a valve to allow air to enter if the oil line gets plugged. The pump, driven by the crankshaft, is also connected to the throttle linkage. It pumps approximately 100:1 at idle, and 50:1 at WOT. The oil from the pump T's into the fuel line just before the fuel pump.
The alarm module compares pump rotation to engine operation. Both present or both missing = OK. One missing sounds alarm. Low oil in the engine tank also sounds alarm.
hope it helps
john
mjm478
Any suggestions to where I can get a replacement cap with the float sensor?
shankforce
You have to buy the whole tank at least last year I think I paid $100. too bad I just gave the repair shop my old motor it still is on it.
j_martin
On the V6 the sensor in in the cap. All you need to buy is the cap.
Smaller engines have the sensor in the tank, and you have to buy the whole tank.
sschefer
PM me with your shipping address. I think I have a couple laying around somewhere.
Faztbullet
OEM part # is 36-43300A9 and about $55
