finding the right engine coupler
farr2gone
I recently got my boat back from a 1 1/2 year experience with a bad mechanic and my coupler went out last weekend on its first run since the new engine was put in. I have an 88 bomber with the 3.0L Mercruiser Alpha 1. When going to order the part by the engine serial I noticed that it is not at all visible on the plate. I can still read everything else on it as well as the drive unit and transom #'s. I don't even want to imagine why its not there but is there any other way before I pull the engine to know exactly which coupler I'll need. Going back to that mechanic is not even an option. Thanks for any help.
Bt Doctur
Re: finding the right engine coupler
Rare to strip a coupler that fast ,are you sure there was oil in the drive.
year and serial numbers
Don S
Without knowing any of the details, my guess is the engine was installed without the drive ever being removed. Some of the hardware under the rear mounts is missing and when everything got tightened down, it was all out of alignment.
farr2gone
yes checked to make sure it was full 2 days before went out. Just cant figure out how to order the right part without the number before i pull the motor
farr2gone
Nothing this mechanic did would suprise me. I found several bolts loose and missing and the tensioner arm to power steering pump was not even there.
Ayuh,... Posting the Info you Do have would be a nice Start....
farr2gone
engine model mcm3.0L
130 hp 181CID
Drive Unit OB803504
I don't know if there is anything else that would help. Not even sure how to find the year of this replacement engine.
Thanks
