HI
i got a 1989 9.9 johnson GT mod CJ10SPCEC 110 psi on both cylinder, it run good idle and wot but in mid range it kind of miss so i change the laminated coil ,the power pack ,The spark plugs and rebuilt the carb...still run bad on mid range the plugs get all wet and wont run back in idle position...change plug and it can idle for as long as i whant.i suspect that it got the wrong carb
The main jet is 54 334014
Aluminium restricor betwin carb and intake of the engine 334852
carb body MX431824
plastic carb top 337833
fuel bowl 333116
carb diameter is 1 inch and at the small midle is around .800 inch
Is theses number look ok?
Thanks jonh.
carb body MX431824
fuel bowl 333116
Thanks jonh.
