1985 evinrude flywheel replacment
basetrimmer
my 1985 150 needs a flywheel but i cant find one like the one that came off it?//
the model # on the moter is e150ancoc can i change the stator annd flywheel to a more common and accessable part
i cant find any parts for this model #
this f.w. is differant than the other ones i can find.
the weights/mags. are between the f.w. and stator 1 mag is broken.
is there a repair i should attempt or is r&r my only option?
thank you Paul
tashasdaddy
Re: 1985 evinrude flywheel replacment
#1 your motor is a 1984 not 1985.
http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1984&ID=278805
0582572 FLYWHEEL ASSY., 35 AMP
0582403 FLYWHEEL ASSY., 10 AMP
http://shop2.evinrude.com/ext/index.aspx?s1=86d3d72aeba35dacbc349b439cb45104
suggest contacting:
SALVAGE YARDS
Try some of these:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
Tim's outboard 218-682-2331
wilde1j
The stator is not user repairable. Replace if damaged.
Faztbullet
There are 2 types of flywheels for that engine, the 9 amp and 35 amp. The 9 amp magnets are molded into flywheel and the 35 amp are glued on and you can get a aftermarket or OEM repair kit.
basetrimmer
thankx faztbullet
can you suggest a vender 4 that repair kit?
basetrimmer
the # on my f.w.is (stamped on the back/ bottom) 582573. is your information still valid for that #?
the model # is e150 ancoc
emdsapmgr
The magnets on the vented flywheels are repairable. Bombardier makes magnet replacement kits. Part number 584304 for one magnet and expoxy glue. May be under $20. If your other magnets are ok and all you need is the expoxy kit to re-glue one magnet, it is sold under part number 431929. Under $ 10. If you decide to replace the vented flywheel, make sure you get the correct part, as the later crossflow models used a near identical flywheel but is not the same part number. These flywheels are NLA.
