chubbybunny
Thread starter- Joined
- Apr 5, 2010
- 13
As a novice boater I could really use some help!
I have a '89 160 Searay with a 3.0L engine and an alpha 1 gen 1 outdrive.
Here's my problem - I was running almost full throttle when I hit something in the water. We belive it was a log, but didn't see it afterwards. Anyway, whatever I hit snapped the upperdrive clean in two right below where it bolts to the gimble housing. I shut the engine down right away and broke out the paddles
So, my questions are: 1. should I replace the entire outdrive or just the upper portion? 2. If the enitre drive, are aftermarket drives as good as Mercruiser drives? Compatible aftermarket drives seem a lot cheaper in price. And finally, 3. what kind of engine damage could have been done having gone from full load to nothing in a second? I haven't started the engine because I wanted some advice before I messed anything else up. I realize from a lot of reading on this forum that gimble bearing, bellows, and impeller are going to be replaced while it's all torn down. Th
